Transmisson to transfer case leak
I just replaced both seals between the transmission and transfer case and I'm just about ready to reinstall the t-case. My question is, the Haynes manual says to run a bead of RTV sealant to the mating surface on the tranny but there was no gasket or sealant there when I disassembled it. There's a small channel that I think acts as a weep hole to alert the vehicale owner to a leakage problem, so wouldn't using a silicone sealant defeat that purpose?
RE: Transmisson to transfer case leak
I dont know how much fluid is in the t-case, however Ive changed the tranny fluid a couple times and there isnt much spillage, only what runs down the tools, and your arms when taking out the bolts. I guarantee you there is more fluid in the tranny than the t-case. I'm pretty sure the the same kind of catch pan you would use if you changed your oil would do just fine.
