adjusting front kickdown band
Has anyone adjusted the front kickdown band on the transmission? I can't seem to get any tools in the small area. I want to adjust the shifting points to be quicker and stiffer. Does anyone have any ideas how to do that. Any opinions or ideas would help. thanks
I don't know what your talking about and suggest you to stop-there is no such thing as a kickdown band, the front band adjustment has nothing to do with shift points, the kickdown is controlled by throttle valve pull over governor pressure. There is no adjustment you can make to to change/qiucken/make stiffer shift points. Back away from the transmission before you break it.
