how to know which gears
Old Sep 28, 2006 | 03:48 AM
98durango4x4's Avatar
98durango4x4
Default how to know which gears
im kinda new to the durango scene so im just wonderin how i go about figurin out which gear ratio i got on the car, is there a certain rpo code or something like that?
Old Sep 28, 2006 | 07:49 AM
Jpondo5.9's Avatar
Jpondo5.9
Default RE: how to know which gears
if you read through the posts on towing and gear ratio they will tell you what you have on you D..
Old Sep 28, 2006 | 09:53 AM
JasonGS's Avatar
JasonGS
Crawl under the back of the car, look on the axle tube over near the driver's side rear wheel. There should be a sticker with your gear ratio, and whether your diff is limited-slip or open.
Old Sep 28, 2006 | 12:49 PM
Mean Green's Avatar
Mean Green
Or you could just look in your glovebox for a sticker on the back of it that tells you all the info you need to know on your D as long as everything is stock. (which is probably 99% of the vehicles out there)
Old Sep 28, 2006 | 12:56 PM
hydrashocker's Avatar
hydrashocker
It's in the glove box.[&:]
