need help with turn signals
Old Sep 30, 2006 | 05:13 PM
jacktruck's Avatar
jacktruck
Default need help with turn signals
I did a search and could not find the answer to my problem. I have a 2000 durango and my blinkers are messed up. they will not work at all any more. At first they would click 4 or 5 times then one day it stopped all together. all fuses have been changed with new ones and bulbs have been checked. i've read other posts with the same problem but no solutions. any help would be greatfully appreciated.
Old Sep 30, 2006 | 06:07 PM
Mean Green's Avatar
Mean Green
Default RE: need help with turn signals
It is most likely the relay it will cost you about 40 bux at Dodge. It is on the other side of your fuse block on the drivers side. You will have to get on the floor of the truck and reach up under the dash and pull the old one. Very straightforward you just have a buttload of wires to go around.
