steering colum
Old Oct 13, 2006 | 03:16 AM
baddiesel's Avatar
baddiesel
Default steering colum
whats up guys new here has any one had a problem with their steering wheel i have no power to mine no horn, cruise or radio controls and my air bag light is on. it seems like it's a dodge thing because my wifes mini van has the same problem is there a easy fix for this
Old Oct 13, 2006 | 12:45 PM
hydrashocker's Avatar
hydrashocker
Default RE: steering colum
WOW![:@]
Never heared about that before. Sounds like you have a bad main fuse or relay. Look under the hood in the main fuse box and check your fuses. Also try to replace your relay with another one and see if it fixes your problem. Most of the relays are the same part number so you can play with them.
Old Oct 13, 2006 | 05:45 PM
baddiesel's Avatar
baddiesel
than you hydrashocker i was reading thru the recalls section and found a recall for it bad clock sring. i just hope the dealers will still honer the recall at this age there is 3 recalls and i never had any of them done never got a notice
