towing with a 5.9
any of you guys to any thing with your 5.9 and if so what do you get for mpg ? i tow a 6500# camper and the thing drops to 6.5 to 7 mpg it's all stock is there any mods that would help get my mpg up
ORIGINAL: hydrashocker
Mine tows like a champ. I also run 392 gears. I tow 5000 Lbs with mine and I can barley feel it.[sm=gears.gif]
I had the intake Cleaned up and polished. I am going to get a M1 from Dan @ www.thefastman.com. He has a killer set up. He bores and polish's all his intakes. The only thing is he wants $450 for it. You can buy them for about $250-$200 for the regular M1. Kind of don't know which one to go with. I am going to go with a super charger so I'm not sure if I need the nicer on or not.[sm=feedback.gif]
Wow, I did not think Fastman charges that much for his polished M1 intake! Nearly doubled the cost. But it will be worth it if it makes a big difference on performance. Anyone upgraded a regular to fastman's M1 and see any improvements in performance?
I wonder how much fastman will sell a package deal for his 52mm Throttle body and his polished M1 intake?
I tow my racecar many, many miles and I average almost 12 mpg with OD off. I figure my trailer and car are about 5,000 lbs. No fancy add ons, just the factory auxiliary trans oil cooler.
Trending Topics
Here is the E-mail Dan sent me when I bought my TB:
TB bolts on with no issues to either manifold.
TB is $219.95, $5 shipping, plus the $80 core deposit to DF members. Free
shipping with the M1.
M1 Intakes I sell as a No Run to the Store Kit. EVERYTHNG included right
down to the Vacuum line. The plenum area is ported removing all the
machining mismatches. $450 for the kit.
If interested in either or both please let me know. I look forward to
helping you meet your performance needs.
Thank You
Dan Arcand
Premium Tool & Mfg LLC
443 E. Viking Drive
Little Canada, MN 55117
651-484-0586 -1
C 651-245-6469
www.thefastman.com
Thank You
Dan Arcand
443 E. Viking Drive
651-484-0586 -1
C 651-245-6469
www.thefastman.com
He Rustin (sp?) if you do get the M1, I'd suggest getting a custom B&G flash done on your pcm to work with the M1. some report a low end loss using the stock pcm or hypertech/superchips programming, the custom flash brings it back. (this is what i've heard, I have no personal experience with it).
you do know the M1 is intended for motors running their power 2500 rpms & up I hope.
One thing I'd suggest on your rig is the 1.7 crower roller rockers. had them on my 2000 ram and they rocked. combined with all the other mods I did to it, the truck would scream from a rolling 70 in OD pretty good. never wanted to downsift which told me it had enough torque for the amount of throttle given. I have to add that I modded the intake manifold on top of all the other mods. that helped breathing significantly above 3000 rpms.
