catalytic converter
Old Oct 19, 2006 | 06:09 AM
mopar34's Avatar
mopar34
Default catalytic converter
Just one of many questions regarding my 2000 Durango. I have had a miss for quite some time and was getting some sort of "silt" material blowing out my exhaust pipe. I had a new throttle posisition sensor put on and it did not change anything. A freind of mine told me that I needed to clean out the catalytic converter and that it would fix the problem. Well, I did just that and now the computer is throwing several different codes. I contacted Chrysler and and they told me that I needed to purchase a new converter for a 4.7L v8 and it would cost me about $600.00 for a mopar replacement. My question to any one out there is, Do I need to put the same converter back on the vehicle that it came with, or can I just find a converter for any v8 dodge truck with the same diameter exhaust pipe?
Old Oct 19, 2006 | 07:26 AM
dodgerules86's Avatar
dodgerules86
Default RE: catalytic converter
As far as replacing the kitty kat goes, you can get one from Jegs or Summit, most of the time for under $100. Just make sure everythings the right size.
As far as installation goes, you can use exhaust clamps. If you wanna get it welded and you or a friend doesn't have a welder, a exhaust shop can usually do this pretty cheap.
Old Oct 19, 2006 | 12:43 PM
hydrashocker's Avatar
hydrashocker
While you are at it get a Hi Flow Performance Cat. You will be happy and when and if you do the exhaust system it will already be installed.
Old Oct 19, 2006 | 12:45 PM
89Daytona's Avatar
89Daytona
What did you use for cleaning out the cat?
What color was the silt?
Old Oct 19, 2006 | 02:54 PM
mopar34's Avatar
mopar34
The silt is black. I can also tell you that the engine is burning very rich. I took the converter off and used a crow-bar to loosen the webbing inside and removed it. I put the empty converter back on the vehicle. Can I use any size converter or do I have to put one just for a 4.7? Any help to this on going problem will be greatly appreciated!
Old Oct 19, 2006 | 03:00 PM
Kensai's Avatar
Kensai
I think you have to go with a converter customed for your vehicle. Because alot of vehicles may have sensors that monitors the pollution level of gases. If you have a converter not tailored for you vehicle, your sensors may throw a code and you may or may not pass inspection.
They make OEM converters as well as performance converters.
So go with Hydra's recommendation and get a performance converter. It will have a higher flow to give you a little more power and I think the cost of a performance converter is not much more than the regular converter. Either of these converters is alot cheaper than getting a OEM converter from the dealer.
Old Oct 20, 2006 | 03:26 AM
steve05ram360's Avatar
steve05ram360
He has a 2000... meaning he has 3 converters, 1 off each e-manifold, then 1 before the muffler. one thing you could do is to find out what is causing the problem with the cats and fix that 1st. I started an O2 sensor cleaning thread over in the 2nd gen ram forum, have a look. it's easy and effective.
