2000 Durango stalls on a cold start
Old Oct 23, 2006 | 09:52 PM
budinski17's Avatar
budinski17
Default 2000 Durango stalls on a cold start
I have a 2000 5.9 Durango SLT. When I start it up in the morning is doesn't seem to want to idle and just stalls. The check engine lite is not on. I can get it running as long as I keep the RPM's up until the engine warms up. Once warm it starts and idles fine. It started doing this once in a while but now it's happening on a more regular bases. Any idea's?
Old Oct 23, 2006 | 11:59 PM
KY Dodge KY's Avatar
KY Dodge KY
Default RE: 2000 Durango stalls on a cold start
My dakota does the same if it sets for a few days without starting. What I do is I turn the key to the on position but dont crank it until about 10-20 seconds and that usually starts it up no problem. This is a common thing with a lot of vehicles. And if that dont work then like you said keep the rpms up until it starts to idle.
Old Oct 24, 2006 | 11:30 PM
budinski17's Avatar
budinski17
mine doesn't have to me sitting for a couple of days, just over night. I just never know when it is going to act up. Tryied your suggestion a couple of times, didn't appear to work. Any idea what the problem part is?
Old Oct 25, 2006 | 12:09 AM
KY Dodge KY
Maybe your in need of a new battery, its just were it may lose some pressure in the fuel rails. then the fuel pump might take a little longer to get the fuel up to the injectors.
Old Oct 25, 2006 | 01:37 AM
IndyDurango's Avatar
IndyDurango
Throttle Position Sensor.
IndyDurango
Old Oct 25, 2006 | 01:32 PM
steve05ram360's Avatar
steve05ram360
IAC valve dirty/sticking. yank it out and clean it... better yet, yank out the TB and clean it too. there is gunk that builds up around the opening of the IAC valve and also a small air passage that gets plugged. it's most likely not plugged but well on its way.
Old Oct 26, 2006 | 11:07 PM
tattoohead's Avatar
tattoohead
A periodic problem on this vehicle is failure of the Powertrain Control Module (PCM). Failure of the PCM may cause an intermittent stalling condition and can also prevent the vehicle from starting.
