Dashboard panel light
I have a 2002 Dodge Durango and I was driving home from work yesterday morning, when the light to my dashboard panel went off. My odometer and other things appears to be working ok except the light. The dashboard will blink whenever you use a turn signal, other than that it is dark. I have seen several post saying to unplug and check the ignition off draw (IOD) fuse. I have looked and I'm not sure what the fuse looks like and how it is labeled on the fuse panel. Please let me know how to locate the IOD fuse and where it is located. I would also appreciate any other help as to how to fix or troubleshoot my problem before I take in to a mechanic.
