transmission shifting rough
Old Nov 1, 2006 | 02:37 PM
blackneon84's Avatar
blackneon84
Default transmission shifting rough
I have a 2000 dodge durango and I have noticed for a while now that it is not shifting as smoothly as it did in the past I heard that if you change the transmission fluid that it will help? Any one else ever had this problem?
Old Nov 1, 2006 | 05:15 PM
Mean Green's Avatar
Mean Green
Default RE: transmission shifting rough
Yep change the fluid every 30k miles and you may just be low on fluid right now.
Old Nov 5, 2006 | 02:37 PM
hydrashocker's Avatar
hydrashocker
Do a full service. Fluid change, Filter, and band adjustment.
Old Nov 5, 2006 | 06:48 PM
steve05ram360's Avatar
steve05ram360
you may have a sticky shift solenoid for whatever gear your having problems with. mine is having a similar issue shifting into/outof 2nd. take it to a good shop and have them look at it. I know there are 2 sensors that can also cause problems, my 2000 ram had this issue... seemed like it was shifting in & out of OD more than it should. swapped the 2 sensors and it was all good again.
Old Nov 6, 2006 | 12:42 PM
hydrashocker
Many of those problems are caused by medal shavings. You can put an inline filter on you trans cooler lines to help that from happening again.
