how to take door panel off
If it is like my 2003 you:
1. pull the pillar trim loose at the back of the door
2. remove 5 screws. 1 under the pillar trim mentioned above, 2 at the bottom, 1 behind the grab, 1 at the handle
3. Lift the panel up and then out
4. Pop the lock and handle loose
5. unplug door/window plugs and speaker
Reverse to put back together.
Good luck
Tyler
Good luck
Tyler
