Rear Speakers Rattle using Bass setting
Old Dec 27, 2006 | 06:19 PM
Tony@vasconis.com's Avatar
Tony@vasconis.com
Default Rear Speakers Rattle using Bass setting
1999 Durango SLT 4x4, with the (6) Infinity Speaker set-up. Rear Door speakers rattle (kinda like the audio is clipped) when I use the bass setting in my "equalizer". If I turn off the bass the rattle goes away. Any idea what's going on?
Old Dec 27, 2006 | 07:34 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Rear Speakers Rattle using Bass setting
sounds like you blew your speaker
Old Dec 27, 2006 | 11:39 PM
Tony@vasconis.com
Yeah
That's what I was thinking too. After I replace it, I should "turn down the volume" ... or ... get a hearing aid.
Thanks
Old Dec 28, 2006 | 12:38 AM
Mean Green's Avatar
Mean Green
If you only blew thesurround foam or w/e it's calledthen you can repair them for a lot cheaper. Do a search on here forspeakers and you should turn up the name of the stuff to use.
