Help on removing radiator fan
Old Jan 9, 2007 | 02:46 PM
DRANGO's Avatar
DRANGO
Default Help on removing radiator fan
Story is my radiator a/c condensor and radiator fan all were messed up by the deer i hit. Now i have everything off but the radiator fan.. The problem im having is when i turn thewrench the nut andthe pulley also turn. To make sure, which way do i turn the wrench and what is the easiest or best way of taking the radiator fan off.
Old Jan 9, 2007 | 08:36 PM
20durango00's Avatar
20durango00
Default RE: Help on removing radiator fan
I did this last year when changing the clutch, had to use a strap wrench around the pulley to hold it still while turning the nut (counterclockwise?).
Old Jan 9, 2007 | 09:02 PM
Haplucki's Avatar
Haplucki
the dealer has a special tool to remove this. I've tried to do this with a wrench and screwed up the nut.
Old Jan 9, 2007 | 09:19 PM
myns's Avatar
myns
they make a narrow wrench for that nut it should have reverse threads (counterclockwise) this is alot easy to do if u leave the belt on while turning that nu it allowes you to help hold it so it doesnt spin
Old Jan 10, 2007 | 05:09 AM
Mean Green's Avatar
Mean Green
Just go get a strap wrench and you'll be fine...
