draining coolant ??
Old Jan 9, 2007 | 08:17 PM
20durango00's Avatar
20durango00
Default draining coolant ??
I turned the petcock drain valve counterclockwise but nothing happened. Does it also pull out after turning?? I drained the coolant this way last year but forgot how the valve worked. Suggestions? Thanks!
Old Jan 9, 2007 | 09:24 PM
myns's Avatar
myns
Default RE: draining coolant ??
did it turn freely sometimes u need a pair of pliers it must rotate a few times
Old Jan 10, 2007 | 05:07 AM
Mean Green's Avatar
Mean Green
My petcock is covered up by theoverflow tankso it's easier just to pull the lower hose... I guess you have the 4.7?
