changed rear end, still grinding
Old Jan 14, 2007 | 07:44 PM
tot1977's Avatar
tot1977
Default changed rear end, still grinding
Please help us, if you can. We just changed the rear end in our 2000 Dodge Durango. Everything fit just fine, gears are the same, etc. Problem is, there is still a grinding noise and no one can figure out why. We added the fluid and the limited slip additive. Like I said, it was just changed today and it is still grinding. Any ideas?
thanks
Old Jan 15, 2007 | 12:35 PM
hydrashocker's Avatar
hydrashocker
Default RE: changed rear end, still grinding
Did you guy's check out the rear axel bearings? Not quite sure if there is an internal bearing before the axel shaft enters the diff or not. But I know there is rear bearings on the axel shaft as it comes out of the hub.
Old Jan 17, 2007 | 12:27 AM
durangatang's Avatar
durangatang
Could be that ... I have to change the whole axle.. does it get noisyer as you accelorate... if so get the axle bearing checked first...
