Shifter stuck in park.
I just went out to my Durango and I cannot get the shift lever out of park. I'm assuming that perhaps the transmission is somehow caught on a gear tooth - I've used a fairly significant amount of force to try to shift down to reverse, although I'm afraid to really put my weight into it for fear of breaking something. Has anyone ever seen this before and have suggestions as to how to get back on the road again?
Thanks!
Thanks!
Agreed. I have only seen this one other time and the user never came back with the fix. I'm thinking it was something dumb and they didn't want anyone to know. What ever the problem we would like a fix for this problem if you find one. Try to move the steering wheel around left to right and see if you can get it out of park. Also try to juggle the key around while doing this.
Have you been stepping on the brake while trying to move the lever? Some vehicles need the brake pressed to shift out of park.
You could take the plastic off of the column and see if anything is stuck around the shifter to keep it from moving (like something in the spring the allows the lever to be pulled back towards youto shift it).
I had a ford that did this once. I had a couple of buddy's rock the truck back and forth while I was
inside moving the lever. This did work, and it only happened 1 time.
Give it a try, and good luck
This just happened to my father in law in his 2002 durango today. To get out of the situation, simply pull off the rubber boot at the base of the shifter. If you look inside you will see a little square metal block that holds the shifter back, with the key turned (not in lock) just press it in with your finger, the shifter will move freely once again. This block should move back on its own when you turn the key on but sometimes it gets stuck. I suspect that it is a loose spring or rod but after a little wd-40 it started working fine again.
Trending Topics
Hey Mean Green, I see you have the BFG AT KO's, how have they been? I realize there is some difference between my AWD 2004 but how have they been. I am looking at tires for my Durango and I like the KO's on my Wrangler. I am between the Michelin SUV tires and the KO's. Any thoughts would be great.
ORIGINAL: HEMI DURANGO 2004
