Maybe it's frozen if you're in one of these nasty areas that is getting this hit. Otherwise I couldn't see why all of the doors would be stuck at the same time...
This happened to me when I lived in Detroit. There was a thin layer of moisture on the outside of the door seal. When the temp. dropped, it froze the driver's side door shut. I felt like an idiot when I had to get in through the passenger side.
Well its latched shut. And I dont have a problem with it freezing im in Florida were its 80 degrees in the winter. Is there a way I can take it apart from the inside?
You'd have to get it open before you can work on it I don't think you could get to all the screws otherwise. Hit unlock a lot and try to open it from the inside. lock and unlock it a few times maybe something is jammed inside and hopefully not just snapped.
