Durango ABS Not Working?
Old Apr 2, 2023 | 11:57 PM
  #31
jims's Avatar
jims
Originally Posted by Tinkeringgreg
Yes I understand rear brakes could leak and do that but I can watch the fluid level in the reservoir drop as I pump the brakes and then the level comes back up when I release the pedal, a leak would not do that.
Seems like you have air in your system somewhere as pumping the brakes appears to be compressing the air (or expanding something flexible) then when you release the pressure it pushes the fluid back into the MC... when were the flexible brake lines replaced or checked ? (I didn't read the entire thread so disregard if you already checked this )
