Can anyone help!!!
Old Jan 24, 2007 | 11:08 PM
bad4.7lt's Avatar
bad4.7lt
Default Can anyone help!!!
I have a 2001 durango, i am on my 2nd 4.7 lt engine. I would like to know if I can put the 5.2 or the 5.9 in this durango without changing the transmission and torgue conv, and will I need to change any of the wiring harness and will I need to replace the computer??? someone please help me the best you can. thanks to all input...
Old Jan 25, 2007 | 03:32 PM
Mean Green's Avatar
Mean Green
Default RE: Can anyone help!!!
You'll be better off keeping the 4.7. you will have to change everything. Do a search on engine swap.
Old Jan 25, 2007 | 09:41 PM
bad4.7lt's Avatar
bad4.7lt
well that what I expected, main thing I wanted to know about was tranny. last time I looked all over creation for a used 4.7 and when I did find one it cost me $2200. when all said and done. I have seen used 5.2 and 5.9 for sale for $700 and more if I needed the wiring and computer that why I was askin. thanksjust trying to learn more about this so I can decide. and of course I still owe on the junker. lol so if i can do it with other than the 4.7 I would like to find out. kinda burned on the 4.7,
Old Jan 25, 2007 | 10:39 PM
deerang's Avatar
deerang
2nd engine eh? what happened to the first?
Old Jan 26, 2007 | 12:54 AM
bad4.7lt's Avatar
bad4.7lt
had overheating problem with the first engine. replaced waterpump and radiator ran good for a few thousand miles, then overheated again and then would not start at all. pulled plugs found water in 2,4,6 cylinders, pulled heads off found hole burnt in 2 cylinder, looked like someone took a blow torch and blew a hole in the piston top, installed a used motor cost about $1500 for a used, drove it for about 10,000 miles and started missing really bad. found water and oil in the #2 cylinder pulled heads found hole agian in same cylinder and looked just like old motor. that is where I am now. I have called some of the local salvage again for engines no one has one in stock, one place can get me one in two days $1250. just dont know if I want to spend the money for a 4.7 or find out what other options I have.
Old Jan 26, 2007 | 10:44 PM
bad4.7lt's Avatar
bad4.7lt
Default RE: Can anyone help! engine swap
where are some of the threads for engine swaps???
Old Jan 27, 2007 | 02:11 AM
steve05ram360's Avatar
steve05ram360
maybe you have another issue that is taking out the motor... low fuel pressure??? causing it to run lean? bad o2 that just is getting past the OBD???
