Question about Temperture???
Just want to ask just in case there is something wrong... while going down the road my car runs at about 180, 190F but when sitting in a parking lot idling it runs up about 230 is this correct or is there something wrong with the cooling system. Im just worried as to what it might do in the summer time. Any help with be much appreciated
Your fan could be bad or your system may be plugged up. Flush the system thoroughly then I would think about a new fan. The radiators in these things aren't big enough for the engine so everything else needs to be optimal...
I second the flush. sounds like you have low flow. also with it being winter... do you ever hear your fan clutch engage? it may have died on you and the only way you see it now is idling...
alright so i hit a deer and i replaced the clutch fan, fan blade and the radiator along with the water pump. so i have newcoolant which iuses Prestone also is there something i did wrong or what. I also hear when just pressing the gas i can hear like water swishing what could that be.. All help greatly appreciated . Just when idling i got to about 230 but once i get going its fine and it goes back down to about 170
It sounds like you may have air in your system. When the truck is cold pull the radiator cap and start it up after it begins to warm up and the t-stat opens up have someone give it some gas while you top it off. Then put the cap back on and fill your reservoir up to the proper level if it isn't.
