Shackle lift, still rubbing 32's
Old Feb 2, 2007 | 10:32 PM
MotoXnut's Avatar
MotoXnut
Default Shackle lift, still rubbing 32's
I've done the shackle torsion lift and love the look and ride height. Problem is my 32/11.5's BFG's still rub when I'm in reverse. I was told that there is somthing called a leveling kit that are essentially spacers that fit above the springs on the Ram trucks. Is there somthing like this for the D's? I really don't want to go more than the 8 revolutions on the torsion rods, but would like to keep my mud gards from ripping off. Any thoughts? Thank you.
Old Feb 3, 2007 | 03:10 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: Shackle lift, still rubbing 32's
what is it rubbing on. you might just have to do some trimming
are you still using the stock rims.
Old Feb 5, 2007 | 02:29 PM
Chris's Avatar
Chris
Do you have springs in the front? I don't believe you do. You will need to do some minor trimming to the areas that are being rubbed. If you are running stock wheels with 32x11.5, you will rub. Those are some big tires to put on a stock suspension truck.
