2000 Durango no heating during warm up
Old Feb 6, 2007 | 07:45 AM
Mean Green's Avatar
Mean Green
Default RE: 2000 Durango no heating during warm up
Big engine takes longer to heat the coolant...
Old Feb 6, 2007 | 11:35 AM
2000DirtyDurangoDD's Avatar
2000DirtyDurangoDD
My Ram had the 5.9 360 and it only took about 10 minutes.Even if I start it early the Durango takes about half an hour to get HOT air and if I don't drive it it wont get hot air at all even if it's at 210 on the temp gauge.My friends backhoe has better heat!
Old Feb 6, 2007 | 02:34 PM
Mean Green's Avatar
Mean Green
So flush the heater core the procedure is stickied at the top of the page.
Old Feb 6, 2007 | 03:34 PM
2000DirtyDurangoDD
ORIGINAL: 2000DirtyDurangoDD
Mine can idle for anhour without heat.I have to drive it for at least 20 minutes until I get hot air.It blows cold to luke warm air until then.I flushed everything so now I'm thinking the heater core is bad.
Old Feb 6, 2007 | 03:44 PM
ganzhimself's Avatar
ganzhimself
It takes a freakin' long time for the D to heat up in the winter. I don't turn on the heater until I get in the car after 10-15 minutes of letting the engine warm up. It usually starts up a little cool, but once I get going it gets warm pretty quick. The temps here in Wisconsin have been well below zero (down to -20 to as low as -35 with wind chill)for the past few days and I've let 'er warm up for 15 minutes and the temp guage barely reaches past 130 until I start driving it.
Old Feb 7, 2007 | 04:37 AM
Mean Green's Avatar
Mean Green
How long did you flush it? Another answer is that it may be too far gone already and needs replacement. I would just run a buttload of water through it bothway before goingand removing it.
