2000 Durango Questions for new owner!
Just bought a nice 2000 Durango SLT 4x4 with the 5.9 V8 with 55,000 miles. Have done some preventive maintenence like flush/change coolant, change differential fluid, change tranny fluid, put in a K&N air filter. What else needs to be done or should I be aware of with this year and model Durango? Any known problems?
The only complaint I have is that there is a lot of condensation from the AC when I am on long drives in humid weather. There is condensation build up inside the glove box where it looks like condensation water is dripping off the some part of the AC back in the glove box. Also get a little condesation from the left driver's vent. Anyone else ever notice this or have similar problems?
Finally, I want to change the spark plugs. What brand do you all recommend. Is it also necessary to change to wires at this time and what brand do you recommend? Finally Is there a cap and rotor that needs to be changed also? Hard to tell because it is cramed all the way in the back. Looks sort of difficult to change out! Also does the Fuel Filter need to be changed and where is it located roughly? Thanks for all your help and look forward to the responses!
RE: 2000 Durango Questions for new owner!
welcome to the boards. here's a site to get ya going. check out the tips and tricks section http://www.intense-dakota.com
good luck
rock
good luck
rock
