Passenger front door look makes a Funky noise
Old Feb 15, 2007 | 06:24 PM
willie2124's Avatar
willie2124
Default Passenger front door look makes a Funky noise
When the doors lock in myh 2000 durango the front passenger lock makes a hell of a noise. It does lock and unlock but something is not right.
Old Feb 15, 2007 | 08:08 PM
PandorianOne's Avatar
PandorianOne
Default RE: Passenger front door look makes a Funky noise
It could just be rubbing/hung on something inside the door. I thought my driver side was shoot until I took the panel off to change the speakers, turns out there was over $4 in change in the door (not counting the pennies [&:]) and it was causing problems. Try taking the panel off the door, and try the locks then, if it still makes a noise, you can trace it a lot easier. There's a good site that walks you through taking the door off for speaker replacement, but it should work for you too.
