Multiple Electrical Problems
I have a 2002 Durango SXT. This past weekend the headlights, power door locks, intermittent setting for wipers, rear wiper (since it is intermittent only), interior dome lights, dash lights and the indicator light for the parking brake stopped working. The low and high setting for the wipers work, the power windows work, the blinkers and hazards work as well as radio, brake lights, etc. I have checked the fuse in the cab panel and under the hood and can't find one that's blown. Any chance I could have dislodged a connection wiht my foot when depressing the parking brake? I didn't see anything obvious nor am I aware of any hidden fuse boxes.
Its been almost a year since Danvt32 posted his problem with a 2002 Durango. I have just experienced exactly the same problem. I even went out and checked the intermittent wipers and sure enough, wipers only worked on low and high. I have looked undeer the dash around the brake and cannot find a third fuse box. I have one on the left side of the dash and another under the hood. I have checked every fuse and relay with no problems identified. Any help is appreciated.
I have a 2003 durango, and now am experiencing the same thing. It seems to be common, as I have seen it on other websites too. But I cannot find the solution. The dealership was worthless.
PLEAAAASSSSEEEE HHHHEEEELLLLPPPPPPPP
thank you
Scott
thank you
Scott
Trending Topics
drkaye
For me it was the Central Timing Module. It was about a $400 fix. It isa recall itemfor a very few 2003 models. Not mine. I am pretty sure it must be repaired by the dealer or an expert. You must re-program your keys, and it needs to exactly match your vehicles options. Hope that helps.
