KEYLESS ENTRY KEY FOB PROGRAMMING
Old Mar 14, 2007 | 12:16 AM
cableguy1224's Avatar
cableguy1224
Default KEYLESS ENTRY KEY FOB PROGRAMMING
Hello everyone,
Do any of you happen to know how to program the keyless entry door openers? I am trying to find out how to when I open the door it unlocks all doors, My rams is easy to do but knowone seems to know how to do the durango
ALSO IT IS A 2003 SLT DURANGO
Thank you for the help hopefully
Old Mar 14, 2007 | 12:54 PM
hydrashocker's Avatar
hydrashocker
Default RE: KEYLESS ENTRY KEY FOB PROGRAMMING
I have seen a lot of posts in the past on this subject. Do a search in the Durango section.
Old Mar 14, 2007 | 11:05 PM
cableguy1224
I did do a search and none have the question I have, ANYONE PLEASE?????
Old Mar 15, 2007 | 12:58 PM
hydrashocker
So let me get this right. You want all the doors to unlock when you just open one door? [sm=huh.gif]
I guess I just don't get what you mean. [sm=WTFsgign.gif]
Old Mar 15, 2007 | 11:40 PM
cableguy1224
Yes that is correct, On my 05 Ram if I am the 1st person to open the drivers door all the doors uplock, On the durango its a pain in a *** to have to hit unlock for the passenger and hit it again for the 2 rear doors to unlock
Hope this makes since, I cant find it ANYWHERE on the internet so maybe its not even possible, I don't know
Thank you
Old Mar 16, 2007 | 10:13 PM
mikesram's Avatar
mikesram
Isn't there instructions in the owners manual on how to program your remote? I thought I came across it at one time.
Old Mar 17, 2007 | 01:52 AM
cableguy1224
It sure is for my 2005 Ram, I would not have asked if it was in the manual LOL
Old Mar 17, 2007 | 04:22 AM
Dodge Tech's Avatar
Dodge Tech
its not a feature on your durango u still have an old style CTM and your 1500 uses a more advanced computer in the cluster.
Old Mar 23, 2007 | 09:21 PM
cableguy1224
Ahh Ha, Thank you I did not know I just plain could not do it, I thought there was a way
Thank you for the info
Old Nov 28, 2007 | 12:08 PM
olddodgefan's Avatar
olddodgefan
This was in another post found here in the Dodge Forums. It worked great on my 1999 D. Hope that it will work on others.
To unlock the doors and liftgate: Press and release the UNLOCK button on the key fob once to unlock the driver's door, or twice to unlock all doors and liftgate. The illuminated entry system will also come on. The system may be programmed to unlock all the doors, on the first press, using the following procedure:
1. Close all the doors.
2. Place the key in the ignition and turn the key between the OFF and ON position consecutively for a total of four times ending in the ON position (do not start the engine).
3. Press the driver's side power door lock switch to unlock the doors and within 30 seconds to lock the doors.
4. You will hear a single chime when programming is completed
