Engine Light P0358
Old Mar 19, 2007 | 07:12 PM
mack24's Avatar
mack24
Default Engine Light P0358
Hi, I have a 02 Durango. Just changed my spark plugs. Went for a test drive and noticed it wasn't running right, and the engine light would stay on. Opened the hood and noticed the #8 wire harness to coil was disconnected. Must have missed it when replacing the plugs. So I connected it back together. It seems to run just fine now. Although the engine light is still staying on. The code is P0358: Ignition coil H primary/secondary ciruit malfunction. I am guessing that must be the #8 coil I reconnected. And that possibly the engine light is staying on because it must be reset now. Is this correct? And if so how do I reset to turn off the engine light? Thankyou.
Old Mar 20, 2007 | 12:55 PM
mack24's Avatar
mack24
Default RE: Engine Light P0358
Well today the problem has dissappeared, no more engine light. It seems to have fixed itself. After going through a search, my next step would have been to disconnect the neg. on the battery for 20 min. But it is not necessary now.
Old Mar 20, 2007 | 12:59 PM
hydrashocker's Avatar
hydrashocker
Nice to see that you got your problem fixed. Ya your light just needed to reset it's self.
