1st Gen Intrepid 1993 through 1997 Intrepids
1994 Intrepid Check Engine Codes
Old May 24, 2007 | 04:55 PM
sassychic0817's Avatar
sassychic0817
Default 1994 Intrepid Check Engine Codes
Someone please help me! I have a 1994 Dodge Intrepid. My check engine light stays on, but I don't understand the codes I got. 7,67,39,54,78...what do they mean? Also, my heater stays on constantly, or shuts off for amoment only to come right back on.....it's summer, I'm hot and don't need heat!
Old May 26, 2007 | 03:23 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: 1994 Intrepid Check Engine Codes
Some of your codes could be powertrain codes and some could be transmission codes.7 2/1 fuel system rich or 2/2 02 sensor short to ground. 39 intake air temp sensor volts low.67 1/1 02 sensor heater failure.78 2/1 02sensor fuel system lean.54 no cam signal.39 and 54 could also be transmission codes, 39 gear ratio error and 54 gear ratio error in 4th gear.
