1st Gen Intrepid 1993 through 1997 Intrepids
97 just one low beam works
Old Jun 15, 2007 | 01:52 PM
bluewolf96's Avatar
bluewolf96
Default 97 just one low beam works
when I switch to low beams only one works. Replaced the headlight (not because of this problem) and it still doesn't work. Hi beams ok on both sides. I don't want to replace the turn signal stem module unless I know it will solve the problem. Thanks.
Old Jun 15, 2007 | 04:36 PM
kurts2's Avatar
kurts2
Default RE: 97 just one low beam works
Do you own and know how to use a multimeter?
Old Jun 15, 2007 | 11:48 PM
bluewolf96's Avatar
bluewolf96
No to both questions, I'm a pretty quick study though. I've got a couple of other electrical issues--one back window will only roll up from the drivers switch and the other back window doesn'trespond to the drivers switch!
Old Jun 16, 2007 | 06:41 PM
kurts2's Avatar
kurts2
It is essential you know how to use one if you want to trouble shoot rather than guess. You will also need a schematic (you can buy a Chiltons at an auto parts store, it has the basics for a newbie). Unfortunatly, you will need to have someone show you the ropes in person, not via a fourm.
