1st Gen Intrepid 1993 through 1997 Intrepids
fast idle 3.5 1995
Old Jun 9, 2007 | 01:31 AM
stormmy22's Avatar
stormmy22
Default fast idle 3.5 1995
95 intrepid idle 2500 and then at 2000 way to fast? new egr,intake gasket,and idle air control valve and still fast autozone told me to put the parts on but no go need help
Old Jun 9, 2007 | 04:30 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: fast idle 3.5 1995
vac leak either intake gasket, or vac lines. Use carb cleaner to find the leak spray around the areaif the rpm changes then u found it
Old Jun 9, 2007 | 11:34 AM
stormmy22's Avatar
stormmy22
Thank you i will try today
Old Jun 11, 2007 | 11:42 AM
stormmy22's Avatar
stormmy22
used a can of carb cleaner no go but i did not add that as it warms up the rmps get higher ?
Old Jun 11, 2007 | 02:43 PM
vanisletrepbc's Avatar
vanisletrepbc
you could also have a bad tps. trotle position sensor
Old Jun 12, 2007 | 02:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Besure the egr gasket bolts are tight. I have had vaccum leaks from the gaskets , unless you had the high idle before? Then the intake gasket maybe leaking.
Old Jun 18, 2007 | 08:40 PM
stormmy22's Avatar
stormmy22
i hade it before the egr thay are tight now i get code 25 and i changed to iac and intakewas done ??
Old Jun 18, 2007 | 08:44 PM
stormmy22's Avatar
stormmy22
also when you get on it hard under load it has a miss like the egr?
Old Jun 26, 2007 | 01:08 AM
stormmy22's Avatar
stormmy22
yes we got it a vac leak in the power boaster runs good now thanks all
