1st Gen Intrepid 1993 through 1997 Intrepids
Error codes Po401 and Po420 for 96' intrepid
Old Oct 17, 2007 | 04:34 AM
ALXcrew's Avatar
ALXcrew
Default Error codes Po401 and Po420 for 96' intrepid
I am seeking some help from anyone, I have recieved the error codes P0401 and P0420. Can anyone help me with this problem. It would be greatley appriciated.
Old Oct 17, 2007 | 04:52 AM
kurts2's Avatar
kurts2
Default RE: Error codes Po401 and Po420 for 96' intrepid
Here is a link for future use: http://www.actron.com/code_lookup.php
P0401
DTC Definition:
EGR Flow Insufficient
P0420
DTC Definition:
Catalyst Efficiency Below Threshold (Bank 1)
Old Oct 17, 2007 | 04:59 AM
ALXcrew's Avatar
ALXcrew
Thanks for the reply kurts2, would you or anyone els have any sugjestions as to fixing this problem. I have considered replacing the O2 sensors. Not shure if doing this will fix both problems.
Old Oct 21, 2007 | 11:07 PM
ALXcrew's Avatar
ALXcrew
Would anyone know if replacing the oxygen sensors first would be the best rather thanreplacing theegr valve first. I am trying to get rid of the check engine light and i have pulled the codes P0401"EGR Flow Insufficient" and P0420 "Catalyst Efficiency Below Threshold (Bank 1)"
