95 I Overheateing
Subscribe
Oct 19, 2007 | 11:05 AM
3.5 overheating...its not leaking at all the water pump isnt grinding/making any noise but this is sucking water...where is it going and what should i look for????!!!!
thanks in advance..
Reply 0
Oct 20, 2007 | 11:47 AM
RE: 95 I Overheateing
you people are useless [:@]
Reply 0
Oct 21, 2007 | 11:27 PM
Have you ck the basic, such the fan coming on, or maybe the engine is misfiring due to water or coolant been suck into engine maybe fromahead gasket that could be leaking. Or maybe a heater core leaking??? Have you a coolant pressure test on the cooling system? Until there is more information I guess none the useless people can help you.
Reply 0
Oct 23, 2007 | 08:02 PM
make sure to get the air out using bleeder valve on top of water neck,
Reply 0
Nov 6, 2007 | 12:39 PM
The 3.5l is a solid motor, but severely overheat it just once and the head gaskets are toast. Do a block test (the blue fluid in a bottle), pull the plugs and check for coolant in the holes and, if none is present, run a compression test.
Reply 0
Subscribe
