1st Gen Intrepid 1993 through 1997 Intrepids
a/c
Old Jun 6, 2008 | 03:28 PM
tehmaxfactr's Avatar
tehmaxfactr
Default a/c
my air condittion isnt working. the problem i can see is that the a/c piece that spins on the belt is not spinning i was wondering what anyone thinks the problem is. thanks
Old Jun 6, 2008 | 03:56 PM
kurts2's Avatar
kurts2
Default RE: a/c
Loose AC belt, or sized up compressor.
Old Jun 7, 2008 | 09:00 AM
tehmaxfactr
Default RE: a/c
well i just got a new belt put on it so i guess it might be the compressor. what exactly does sized up compressor mean? i am kinda a noob when it comes to car lol.
Old Jun 7, 2008 | 10:24 AM
kurts2's Avatar
kurts2
Default RE: a/c
check (with engine off) if you can turn the compresor by hand. If you can the belt is too loose. If you cant, remove the belt and see if you can turn the compressor by hand. If you can't it's sized (locked) up. aka broken. You will need to have it replaced by an AC mech, If you remove it, the linses need to be purged and vaced.
Old Jun 10, 2008 | 08:00 PM
ralphael101's Avatar
ralphael101
Default RE: a/c
We may be assuming that you have freon in the system already. If you don't, the compressor won't turn on. If it turns on for a short time and turns off.....then repeats this.....you are simply low on freon. You can purchase the freon, oil charge(needed to lube the comressor), and the hose needed to refill the system at any auto parts store for under $40.00. Has the ac worked before? Also if you are doing this yourself,the ac needs to be on when you add the freon and oil charge. Only add the freon to the low side of the system.....On top of the compressor you will see a low and a high side line....marked by an H and an L.The compressor will turn on after you start adding the freon.Hope you don't have any leaks.Good luck. P.s. Walmart is best price here for ac supplies.
Old Jun 11, 2008 | 04:51 PM
kurts2's Avatar
kurts2
Default RE: a/c
ORIGINAL: ralphael101
If the freon was low, the clutch will not engauge, so the compressor will "free spin". Tha't to say, spin very easy with no load. What tehmaxfactr reported was "i can see is that the a/c piece that spins on the belt is not spinning". That's why I said belt or compressor.
