Need Help Plz! 95 dodge intrepid wont turnover
ok well i replaced my radiator and took my timing chain cover off to change out the water pump "note":'timing never moved, had 2 people holding the belt/gears in place" after everything was put back together i tried to turn the ignition over and it cranked but never fired and it wasnt a problem until i changed my radiator and took off my timing cover. Any ideas would be very appreciated , someone told me these vehicles have a crank sensor or something by or inside the timing gears that couldve broke any ideas would really help cuz i have no idea.
I'd recheck your timming. Align the marks. As for a CAM or CRANK sensor, you would have an engine code. Note, when my CRANK sensor on my 97 went out, I did NOT have an engine light, only the code! Do the key turn trick to see if any codes. I would bet the belt is off though, as it was working prior to the pump change.
