1st Gen Intrepid 1993 through 1997 Intrepids
96 Intrepid Gauges Not Working
Old May 19, 2009 | 10:39 AM
soointrepid96's Avatar
soointrepid96
Default 96 Intrepid Gauges Not Working
I have a 1996 Intrepid and recently have had the following issues. The check engine light is on most of the time, but when it does go out, all the dash gauges stop functioning as well. (Fuel, tack, Speedo, temp). I had my local mechanic check and he pulled the following codes.
P1598 AC Pressure
P1695 No Body CCD Msg
P1899 Park Neutral Switch
P0462 Fuel Sender Volts low
P1698 No Trans message.
Other than the annoyance of the Check Engine Light being on, there seems to be no issues with any of the faults that appear. The AC works fine, car drives well and gas mileage is ok.
Are these issues related?
Is there a simple inexpensive solution?
Any help would be appreciated. thank you.
