1st Gen Intrepid 1993 through 1997 Intrepids
1997 dodge intrepid fuel pump problems
Old Sep 23, 2009 | 06:16 PM
phatbecker's Avatar
phatbecker
Default 1997 dodge intrepid fuel pump problems
Fuel pump went out. Dealer said it would cost $800 to replace ($400 part/$400 labor). Not sure I want to lay down that much cash.
I am somewhat mechanically inclined but I am not sure if I should attempt this.
Anyone ever done this? If so, do you have instructions?
Can anyone recommend a fuel pump to buy?
Thanks in advance
Old Sep 25, 2009 | 06:47 PM
22dodge's Avatar
22dodge
they are the easiest fuel pumps to change. just open the trunk, pull back the carpet behind the seat, get a 10mm socket, remove plate, disconnect fuel lines and wire plug in, take a flat blade screwdriver and unscrew a big hose clamp. pull pump straight out.
Go to the JY and get a used one (90% chance it's good) or go to ANY auto parts store
see what going JY rates are at www.car-part.com
