1st Gen Intrepid 1993 through 1997 Intrepids
1997 Dodge Intrepid Engine Cradle/Suspension Crossmember Bushings Falling Out
Old Apr 9, 2010 | 10:10 PM
phatbecker's Avatar
phatbecker
Default 1997 Dodge Intrepid Engine Cradle/Suspension Crossmember Bushings Falling Out
Took 1997 Dodge Intrepid 3.5L in to mechanic to have it checked for heavy clunk / thump from front suspension area and found that it needed:
All upper and lower bushings on crossmember replaced - $350 Labor $450 Parts
Lower Ball joints..arms worn - lower control arm replaced - $275 Labor $320 Parts
Left front bearing assembly (loose) replaced - $80 Labor $140 Parts
Steering rack bushings (left) replaced - $450 Labor $100 Parts
Total ~$2200
I think the most pressing issue is the crossmember bushings.
I am not going to have the mechanic fix these as the car is not worth half that, but I was wondering if these could be done by someone who is somewhat mechanically inclined (I have done simple jobs like replaces fuel pump, fix inner tie rod bushing). Otherwise, I guess I will be looking for another car.
Any hints/help on how to fix this?
Thanks,
Matt
Old Apr 11, 2010 | 10:52 AM
phatbecker's Avatar
phatbecker
I guess I need to make this more specific.
How do I replace the crossmember bushings on a 1997 Dodge Intrepid 3.5L and where do I get the bushings?
Thanks,
Matt
Old Apr 12, 2010 | 11:15 PM
kurts2's Avatar
kurts2
Dealer only parts, and from what I heard, the engine d/n have to be pulled, only jacked up enough to replace them one set at a time. I have not tried this myself though.
Old Apr 15, 2010 | 12:08 PM
Larrz's Avatar
Larrz
I have done this, it is fairly easy. the bushings are two pieces, they slide together, one on top and one on bottom. the only trouble I had, was one of the nuts spun inside the frame. I had to cut an access hole to get a wrench on it, then welded closed. These are dealer items, around $90.00 a piece.
Old Apr 17, 2010 | 12:01 PM
ralphael101's Avatar
ralphael101
I've seen them sold on ebay. They were listed as subframe bushings. If I remember right....they were an improvement over the factory ones. And yes, the things you need to replace are pretty easy on this car. Thats one of the many things I like about this car.
Last edited by ralphael101; Apr 17, 2010 at 12:03 PM. Reason: adding more info about ebay item
Old Apr 24, 2010 | 09:45 AM
phatbecker's Avatar
phatbecker
Thanks for the replies
Do you know where I should place the jacks when I replace the subframe/crossmember bushings?
Old Apr 25, 2010 | 10:09 PM
ralphael101
Just make sure you do one at a time and all will be smooth. I placed mines just behind the firewall, as if I was changing a tire. I didn't want it under the subframe because as I loosen the bushings...I wanted the weight of the engine to break the rust sealed bushings apart. Then I took another jack (you could do this with one jack) and jacked the frame back up to tighten the new one. You may have to pry them out a little because of the rust. The engine should do most of it for you. Hope this helps you out. Be safe!
Old May 18, 2010 | 05:05 AM
Dodge1996's Avatar
Dodge1996
if you decide not to fix the intrepid
let me know bro...ill take the engine cradle of your 1997 intrepid...
Old May 20, 2010 | 07:14 PM
phatbecker's Avatar
phatbecker
Got the bushings on..thanks all for your help. I used the bushings from polybushings.com The rear mounts were rusted together so I had to sawzall them off and order some salvaged ones from polybushings.com (great place to work with).
Thanks again
Old Sep 19, 2017 | 06:03 PM
Autoloader's Avatar
Autoloader
Default replacing subframe bushings
Here is what I did guy's and I didn't have any issues at all. I used one jack and centered it between the front and rear subframe. I hade my Wife to jack it up enough to know I had the weight of it. I removed the front and rear bolt and had her slowly let it down until I could remove the upper bushing on both front and rear. I replaced with new bushings (Dorman pt # 924-001) @ the tune of $57.99 each @ Orielys. As she jacked it up it helped to push the new bushings in. Then I replaced the lower bushings and bolts and torqued to specs. I repeated the same process on the passenger side and all went smooth without any problems. from start to finish 1 hr. 15 min. I hope this helps someone.
