1st Gen Intrepid 1993 through 1997 Intrepids
94 Intrepid 3.5L V6 Wiring problem?
Old Apr 23, 2010 | 03:51 PM
Kflow123789's Avatar
Kflow123789
Default 94 Intrepid 3.5L V6 Wiring problem?
I need to know how to find a short in the wiring, I posted a thread about my radio, interior lights and power locks not working anymore because of my e brake and still can't figure it out. If it is a short I need to find it but I don't know how. There is no blown fuses so I'm at a loss. Driving without a radio is terrible so I'll do pretty much anything to fix it.
Old Apr 23, 2010 | 04:28 PM
Kflow123789
Bump.. Please help.
Old Apr 25, 2010 | 09:55 PM
ralphael101's Avatar
ralphael101
First, make sure you separated and covered any exposed metal in the wiring. Next, tie them out of the way so that it doesnt happen again. A simple wire or cable tie, or electrical tape can help with this. Then take off your fuse panel cover and look at the inside of the cover. Do you see the spot that says "power locks and power seats"? Thats a relay. That may be your problem. But since you have multiple problems all at once on separate systems...I would check the fuses under the hood near the drivers side fender. I'll bet thats where your problem is. Just guessing though. But I think this is a good start.
Old May 1, 2010 | 11:59 PM
Dodge1996's Avatar
Dodge1996
if u checked all the fuses and nothing yet appears just rewire everything...ill guide you thru...just pm me
Old May 6, 2010 | 04:49 PM
Kflow123789
For future reference to anyone else with this problem, it was an m1 circuit that wasn't getting power.
