1st Gen Intrepid 1993 through 1997 Intrepids
Question?? help!
Old May 18, 2010 | 05:28 AM
Dodge1996's Avatar
Dodge1996
Default Question?? help!
would a 1996 Chrysler LHS engine cradle fit a 1996 dodge intrepid?.
the only difference is that my intrepid is a 3.3L V6 and the 1996 Chrysler LHS is a 3.5L V6.....is there any diference other than the motor??...
Old May 18, 2010 | 09:16 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
this should be in the intrepid section, ill move it for you
Old May 18, 2010 | 05:35 PM
Dodge4lyfe's Avatar
Dodge4lyfe
shouldn't be, they are both LH body cars...I'm not sure of the compatibility of the 3.3-3.5 mounts though. IIRC the mounts are the same on the cradle but the rest of it that bolts to the block is different. So i believe it will work.
Old May 18, 2010 | 08:29 PM
Dodge1996's Avatar
Dodge1996
thanks brotha!
