1st Gen Intrepid 1993 through 1997 Intrepids
1997 interpid with codes
Old Aug 27, 2010 | 03:25 PM
Stephen Bolger's Avatar
Stephen Bolger
Default 1997 interpid with codes P0175,p0300,p0302,p0304,p0306,p0171
I have a 1997 interpid sport 3.5l With these codes P0175,p0300,p0302,p0304,p0306,p0171.
I have replaced spark plugs ,spark wires, O2 sensors, coil pack, fuel injectors, Battery.
could it be one of the following?
map sensor bad?
camshaft sensor Bad?
Crank Shaft Sensor bad?
Fuel pump?
Timing belt?
Old Sep 1, 2010 | 05:39 PM
Stephen Bolger
Any help would be helpfull..... I am to the point of pulling the motor and rebuilding it.
Old Sep 1, 2010 | 08:06 PM
sapporo's Avatar
sapporo
to me, codes really mean nothing without symptoms, data stream information from the scanner. you could have bogus codes from something getting unplugged while the key was on.
I never 'fix' a car based on just the code. that'll lead you down the wrong path and cost too much time and money. a code is just one small segment toward proper diagnosis.
Old Sep 2, 2010 | 06:04 PM
Stephen Bolger
I think i found the problem. i have fuel running out the vacum line that goes to fuel pressure regulator. so i think the fuel pressure reg is bad.
Old Sep 2, 2010 | 06:25 PM
sapporo's Avatar
sapporo
that's great and see how something really unrelated to all the sensors and computer caused erroneous codes.
