1st Gen Intrepid 1993 through 1997 Intrepids
wobble in the steering
Old Nov 17, 2010 | 01:42 PM
Kirk Stone's Avatar
Kirk Stone
Default wobble in the steering
I have a "97 Dodge Intrepid that has developed a wobble in the steering. It seems to come and go, but it is getting worse. Any ideas on what is going on?
Old Nov 22, 2010 | 10:42 PM
Stephenopolus's Avatar
Stephenopolus
Does it get worse, get better, or stay the same when you apply the brakes? when you turn left? turn right? accelerate?
May be a wheel bearing but check the tie rod ends first. If they break you will loose control. My '95 intrepid eats tie rod ends, especially the inner ones connected to the power steering. It is right above the transmission and behind the top of my 3.3 engine. Very poor heat protection makes the rubber bushings break down faster.
So, check Tie Rod End bushings, wheel bearings, may also check A-arm I had to replace my lower A-arm bushings but I forget what the symptoms are for that. Keep in mind mine is a '95 and I don't know what changes were made if any for the '97 but for safety sake check the tie rods first.
Old May 16, 2011 | 05:06 PM
sage_viper's Avatar
sage_viper
I'm having the same issue with my '97 that I just got. My uncle works in a repair shop for Dodge and said that it's probably a drive line going bad. Those run about $50 a pop if that's the issue.
Looking at the manual I just picked up, it could also be "worn or damaged inboard or outboard CV joints"
Old May 18, 2011 | 06:18 PM
Chewievette's Avatar
Chewievette
Steering problems on the LH cars can almost always be fixed or greatly improved by replacing the inner tie rod ends. On the first gen I would also recommend replacing the cradle bushings, if those are bad you will hear a random clunk, loose steering, random wandering, etc... On my car I replaced them with poly bushings from www.polybushings.com (which are actually cheaper than OE) and it felt like an entirely different car.
Old May 19, 2011 | 01:19 PM
kurts2's Avatar
kurts2
Easy inspection...jack the car and push/pull on the tire and inspect where the slip is. I'm leaning toward the inner tierod ends.
