1st Gen Intrepid 1993 through 1997 Intrepids
no start no crank signal
Old Apr 2, 2011 | 11:26 AM
hellbent72's Avatar
hellbent72
Default no start no crank signal
got a 97 3.5. cranks no start. the car is new to me and sounds kinda funny when its cranking over. timing belt seems to be good. new coil pack new crank sensor. im getting no crank rpm on my scanner when im cranking the car over
Old Apr 2, 2011 | 12:10 PM
hellbent72's Avatar
hellbent72
i was also told the car has a new timing belt. car ran fine parked it and no start only after a few hours
Old Apr 3, 2011 | 12:20 AM
kurts2's Avatar
kurts2
Crank sensor or plug?
Old Apr 4, 2011 | 09:44 AM
vineugn's Avatar
vineugn
hello,
I have a 2001 dodge stratus with a 2.4 liter. The motor went out and I replaced it with a 2003 2.4 salvage yard motor. The problem I'm have is I'm only getting firing from the # 1 and 4 cylinders. # 3 & 2 are not firing. Needing answers on where and what I may need to do to solve this problem. I have compression, gas, but no spark from plup wires 2 and 3.
vince
Old Apr 4, 2011 | 12:02 PM
hellbent72's Avatar
hellbent72
crank sensor is new from advance. its a bwd unit. the plug was oily but the wires looked good and seem to be making good connection
Old Apr 4, 2011 | 12:04 PM
hellbent72's Avatar
hellbent72
you may need a new coil pack. 1&4 fire at the same time and 2&3 fire at the same time
Old Apr 4, 2011 | 02:57 PM
vineugn's Avatar
vineugn
Default 2003 dodge stratus
I used the coil from my old and new salvage motor and i'm getting the same results. Would the crank sensor on the 2003 motor play a part in it not starting. The 01 crank sensor is different than the 03 sensor but the plugs are the same. It seem strang that bolt coils are doing the same the and they look identical. your feed back is greatly appreciated.
vince
vsimmons@austincc.edu.
Old Apr 10, 2011 | 09:15 AM
kurts2's Avatar
kurts2
Vineugn...if you haven't tried a wire set, i'd try it first. It could be you just have two bad wires. If not, work your way back from the coil to the computer. Also be very careful with the signal plug to the coil pack...a spread pin on the connector is enough to cause your problem.
Hellnent 72... I'd start with cleaning the dirty connection, an oily plug is not what id call a good connection. You could also look at the ASD circuit.
