1st Gen Intrepid 1993 through 1997 Intrepids
Mechanical confusion
Old Sep 21, 2011 | 10:44 AM
Cougar1068's Avatar
Cougar1068
Angry Mechanical confusion
My '97 3.5L is giving me a migraine. It will start and idle just fine until; it warms up or I put it in gear, and once it's warm it'll start than immediately die. No codes from dash board or OBD II. Has anyone else had this problem?
Old Sep 23, 2011 | 08:17 AM
22mopar22's Avatar
22mopar22
check for vacuum leak under intake very common. with the engine running spray carb cleaner around the intake. if you hear engine speed change, you found the problem.
