1st Gen Intrepid 1993 through 1997 Intrepids
94 intrepid es transmission problem
Old Oct 29, 2006 | 01:34 AM
kimntony's Avatar
kimntony
Default 94 intrepid es transmission problem
Please Help!! I just purchased a 94 interped es 3.5. The transmission seems to be stuck in low gear. I can get it up to a good speed but the rpms run about 4, and the transmission knocks very hard. Any ideas?
Old Oct 29, 2006 | 06:54 AM
kurts2's Avatar
kurts2
Default RE: 94 intrepid es transmission problem
I just changed a speed sensor (output) and fixed mine. Mine however also had the speedometer inop. If yours isn't (if it works), you may want to try the speed input sensor (a 25$ guess) to the transmission. Both sensors are located on the left rear side of the transmission (just behind and above the left axel). Are you having any other probs (ie engine codes, speedometer ect)?
PS the output sensor is the futher aft one while the more fwd one is the input sensor. Also they are not interchanable.
Old Dec 3, 2006 | 12:41 AM
Intrepid Scarface's Avatar
Intrepid Scarface
ORIGINAL: kimntony
Limp mode...
It's programed as a precaution. If the computer sences something is fuked in the transmission, it will disable the third and fourth gear.
Take it in and have it checked.
With the knocking...it looks like your transmission is about to flatline.
If it jerks in the process, your gears are slipping, check transmission fluid and the level. If the fluid is milky, get the transmission replaced. You may also be able to get an oversized filter for the transmission to make the 60k mile fluid change intervals easier to live with.
Go to DI.NET if my option fails.
Old Dec 3, 2006 | 04:45 AM
popimp's Avatar
popimp
You're all over this website scarface more rep for you.
Old Dec 3, 2006 | 04:14 PM
Intrepid Scarface
ORIGINAL: popimp
LOL
Someone on this network has to be able to answer a few questions. That and I'm showing them the light, DI.NET.
Old Dec 13, 2006 | 06:32 AM
no_name's Avatar
no_name
i think my tranny is going out too, man im pissed, ive only had the car less than a week
Old Dec 13, 2006 | 02:28 PM
Intrepid Scarface
ORIGINAL: no_name
Have a mechanic look at the transmission, if it's serious, have them make out a statement.
You may be able to take this to court.
There are a few questions that apply before the legal stuff :
Did the seller say that there were any problems before the sale?
Have the transmission been slipping/getting worse since you had it?
There is one other question, but I can't think of it yet.
Old Dec 15, 2006 | 07:13 AM
no_name's Avatar
no_name
not in this state plus we both sighned as is papers, the shop wont extend the warranty to me , he said that he would see if the co he got the trque convertor from might warranty their part if its bad and i remove it, i think its a bad flexplate personaly, so im gunna check it tomorrow hopefully, u know remove the inspection plate and see what i can see, it dont slip one bit either it drives fine it just makes noises
