1st Gen Intrepid 1993 through 1997 Intrepids
3.5 Tranny Questions
Old Jan 12, 2007 | 12:47 AM
logans08's Avatar
logans08
Default 3.5 Tranny Questions
Ok. I'm buying an intrepid from one of my buddies and the tranny is bad on it. It is a 3.5 Sport. I was just wondering what the difference between the tranny on a Sport is and just a regular tranny out of a 3.5 and if it would work in there or not. I know on the Sport edition they have autostick. But yeah any help on this would be wonderful. Thanks guys
Old Jan 14, 2007 | 06:35 PM
logans08's Avatar
logans08
Default RE: 3.5 Tranny Questions
i would also like to know if anyone has an idea what went wrong with the tranny. first and second gear work great, but if the car shifts into third and up its like it is in a neutral gear. any ideas anyone?
Old Jan 27, 2007 | 10:34 AM
skynyrdcat's Avatar
skynyrdcat
Sounds like a solenoid.
The trannys have a built in defense mechanism to prevent from doing serious damage (in the event of a detected problem) drive and over drive are disabed (leaving only first and second).
I've never opened up a dodge tranny but I've had the same problems on other cars and it was relatively easy to fix. It would be worth while to have a trany shop hook the scan tool up and tell you for sure.
Some solenoids can be replaced witha fairly basic pan pull.
Some are farther into the body of the transmission.
I'd get it checked and find out which solenoid and where it it located in the transmission.
May save you some $$$ if you're a "do it yourselfer"
Old Jan 27, 2007 | 10:49 AM
skynyrdcat's Avatar
skynyrdcat
almost forgot!!!
It could also be a speed sensor or something that can easily be replaced from te out side.
Again I'm no Dodge transmision expert, but I do have some similar experiences.
I bought a 96 Mazda (with same condition) for $300 put a $30 VSS (fixed the problem) and sold it for $1800.
I bought a 98 Nissan (same condition) for 600 bought a 300 solenoid pack (installed it by simply removing the pan) fixed the problem and sold it fr 2k.
I would definately buy the Haynes manual, this will tell you how to check the VSS etc.
If it pulls good in 1st and 2nd, and the fluid level wasn't excessively low (or have a scortched smell) you may be able to fix this fairly easily.
Let me know what you find.
SKYNYRDCAT
Old Feb 19, 2007 | 10:38 PM
twburger's Avatar
twburger
There may be a difference. It depends if the sport engine has a higher output. The 3.3 liter version transmission differs from the 3.5 liter version internally. The 3.5 has bigger and stronger parts. Your best bet may be to check the serial number for the transmission code and see what tranny it has.
Old Feb 27, 2007 | 01:36 AM
vanisletrepbc's Avatar
vanisletrepbc
On the side of the tranny there is 2 sensor. Input speed sensor and output speed sensor, when one or both of those sensor fail the tranny goes into limp mode .Bet you it's one or both of them.
Old Jun 7, 2007 | 11:01 AM
rowdysandy's Avatar
rowdysandy
[&o]I have the same problem with my tranny hoping logan would have said if it fixed his problem but thanks for the help...... gonna call and get an appointment to get my tranny read as soon as shop opens lol
Old Jun 7, 2007 | 01:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
There no difference's, all of the 42LE trans are the same. and the term you are looking for in Limp-in mode. That only gives you 2nd gear, to limp in to the local dealer or trans shop.
