fuel filter question
Old Apr 3, 2007 | 07:38 PM
NEONRT98's Avatar
NEONRT98
Default RE: fuel filter question
Are you sure that "silver thing" on top isnt the FPR?
Old Apr 3, 2007 | 07:41 PM
spudsterier's Avatar
spudsterier
the silver thing on top of the pump for the plastic tanks is the fpr....but it doubles as the fuel filter
Old Apr 3, 2007 | 10:56 PM
crow01's Avatar
crow01
Here's a theoretical question. What if someone did install a 2nd filter, what is the routing for the fuel lines? Mine comes out of the pump(one line), then goes to a silver cylinder, then out to the hard line running to the front of the car. The line coming out of the pump doesn't have the plastic quick disconnect, it has the metal hose clamp on it. Does this matter? Is it possible just to bypass the second "thingey"? It just seems that every now and then, my car seems to idle a little low, and I'm wondering if this could be the reason.
Old Apr 4, 2007 | 12:50 AM
spudsterier
if there is a hose clamp back there then sumone has done some work to it previously.....
Old Apr 4, 2007 | 01:00 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
True....but why I wonder?
Old Apr 4, 2007 | 01:37 AM
spudsterier
honestly i couldnt tell ya.....maybe sumone just not knowing what they were doin????
Old Apr 4, 2007 | 02:24 PM
crow01's Avatar
crow01
Thanx for the assistance. On Friday, I'm going to a junkyard that has a couple Neons in it, and I'm crawling underneath to see what I can see. When I figure it out, I'll post it for future trouble-shooting.
Old Apr 7, 2007 | 03:19 PM
crow01's Avatar
crow01
Went to the junkyard, and discovered what is called a fuel accumulator? Every neon that I could get under had this on it. What is it, and what does it do? It appears to be the "fuel filter" that all the auto part stores stock.
