sohc engine with dohc head??
Old Apr 4, 2007 | 04:08 PM
96 srt4's Avatar
96 srt4
Default sohc engine with dohc head??
will the head on a dohc bolt on to a sohc block??
Old Apr 4, 2007 | 04:18 PM
Revenger08's Avatar
Revenger08
Default RE: sohc engine with dohc head??
Yes the block will match up with either the DOHC head or SOHC head..... The engine is the same just different heads.
Revenger08
Old Apr 4, 2007 | 04:40 PM
96 srt4's Avatar
96 srt4
why is the head gasket different??
Old Apr 4, 2007 | 06:17 PM
das2123's Avatar
das2123
ORIGINAL: 96 srt4
Because the HEAD is different. You need more than just the head to do the swap...
https://dodgeforum.com/m_599520/tm.htm
