TDC question
Old Apr 4, 2007 | 10:29 PM
Psurichie's Avatar
Psurichie
Default TDC question
Does the #1 pisten have to be on the compresion stroke to find tdc and if it does how do you know that With out a compression tester ???
Old Apr 5, 2007 | 12:16 AM
spudsterier's Avatar
spudsterier
Default RE: TDC question
take out the spark plug......set your hand over the hole and turn the motor over.....
when you feel the air push your hand up, then your on the compression stroke
Old Apr 5, 2007 | 11:46 AM
das2123's Avatar
das2123
But that doesn't tell you its at TDC
Old Apr 5, 2007 | 11:53 AM
spudsterier
he asked was how to know if its on the compression stroke..
but
you can take a wooden doll rod or a long screwdriver and place it in the spark plug hole....while cranking the moto..(by hand)....watch the rod and when it reaches its highest point then its at TDC
Old Apr 5, 2007 | 11:59 AM
das2123's Avatar
das2123
ORIGINAL: spudsterier
ORIGINAL: Psurichie
Old Apr 5, 2007 | 03:28 PM
spudsterier
yeah i know...i read that after i posted it
Old Apr 5, 2007 | 08:03 PM
Psurichie's Avatar
Psurichie
Thank You
