crank/cam re-learn question
Old Apr 6, 2007 | 09:55 PM
BigBlocksnHardRock's Avatar
BigBlocksnHardRock
Default crank/cam re-learn question
I was going to help my brother do a timing belt on his 96 neon. But the procedure in AllData ends with having to do a crank/cam relearn with the DRB.
Would the vehicle not start after doing the belt if not re-learned? Or will it start and run like ****?
Thanks.
Old Apr 7, 2007 | 01:00 AM
das2123's Avatar
das2123
Default RE: crank/cam re-learn question
If the timing marks are lined up correctly, then it will run fine.
