SOHC pistons
ORIGINAL: racerx55
have you guys ever had the eclipse motor and a neon motor apart at the same time? theyre identical other than reverse airflow direction in the head
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
ORIGINAL: racerx55
( honestly i wish neons came with the 4g63) 420a is a heap of ****
![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
ORIGINAL: das2123
What about the water outlet location? ![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
The neons DON'T have the 420a engine
. What about the crankwalk on the 4g63 engines? I have heard something about this.
ORIGINAL: racerx55
ORIGINAL: racerx55
This is in a 95 eclipse RS, I bought the car for $400, had a broke timing belt. I pulled the head, had 4 bent valves. I had the head completely rebuilt including the valves for $150!!!. By a proffesional machine shop. I decided to pull the pistons while I had the head out, rod bearings looked good. The pistons showed a lil bit of scuffing on the skirts, I just assumed to put lower compression pistons in it since I planned on boosting it anyways. The cylinder walls still had the cross-hatching. Im going to hone the cylinders, put new rings, and rod bearings in. Im going to try out the Ebay, JIS gasket kit, it comes with a MLS headgasket. I pulled the pistons and the rods with the block in the car.
For fuel, I bought some 35lb/hr SVO ford injectors for $20 on ebay, I bought a used vortech 12:1 FMU from a guy local for $35.Walbro 255hp-$100 Im going to buy a SAFC. I got an EGT guage out of a freightliner, the probe is $28 at my cost, because I work there. I got a t-25 off of a SR20DET for $80 on ebay. This is going to be as budget as it can get.
Has anybody ever put a regulator on the boost side of an FMU to finely tune high RPM fuel trim?. If my theory is correct, with 300hp, 360cc/min fuel injectors, 72 psi fuel pressure is all I would need. my 12:1 FMU would be to much fuel at 9-10 psi boost, so if you put a regulator on the boost side, the boost side would only see 6-7 psi. Only because im running bigger than stock injectors.
what do yall think, does this make any sense.
